Gear selector knob removal Disco I
Old Jan 8, 2012 | 11:26 AM
rcook's Avatar
Default Gear selector **** removal Disco I
Can someone tell me how to remove the gear selector **** on 97 Disco I?Trying to replace torn up selector sliding tape. Everything is out except can't get **** off. Any help would be greatly appreciated.
Old Jan 8, 2012 | 11:33 AM
jafir's Avatar
Pop the cover off the top with a small screw driver. Remove the clip. Remove the plastic wedge thing. Remove the button from the side. Remove the nut. Pull up.
Old Jan 8, 2012 | 11:49 AM
hh65flyer's Avatar
That's it! There's a small clip on top of the wedge-thingy. Once you take that off, it all comes apart.
Old Jan 8, 2012 | 11:53 AM
rcook's Avatar
OK, so there is a nut below all this and once removed the **** can be pulled off?
Old Jan 8, 2012 | 12:09 PM
hh65flyer's Avatar
Yes. I think it may require a deep-well to get down past the stud and it's a fairly large one.
Old Jan 8, 2012 | 12:48 PM
rcook's Avatar
Success !!!...has "murphy" would have it got to the last brass screw in upper left corner and the head stripped out, finally worked it out w/needle nose pliers. Thanks to all for the suggestions. I'll let u know how it all goes back together.
Old Jan 8, 2012 | 05:49 PM
Paul Grant's Avatar
19mm nut. Most often you don't even need a socket. A flat head screwdriver can be used to loosen the nut. It's usually on that loose.
growlinbear 2013
Jan 24, 2013 01:08 PM
bcolins
Jun 10, 2011 11:36 PM
old gold
Nov 12, 2008 11:18 AM
fpapai
Oct 29, 2007 12:30 PM
Lebowski87
Jun 1, 2006 04:23 AM
