Radiator bleed screw... Son of a *****
Old Sep 2, 2012 | 09:45 PM
L8brakelou's Avatar
Default Radiator bleed screw... Son of a *****
Ok so a heater hose decide it would leak today. So I figured no big deal went to autozone to get a cheap replacement until I can order a Oem one. I got just some straight hose that would work and installed it. So I decide it's time to bleed the system. Put a wrench on that awesome plastice screw and snap... The head came off lol what's weird is I jammed a flat head screw driver in the threaded part and it unscrewed just fine.
So now my question, Does anybody know of a plug that will fit in there until I can order the Oem part? Or maybe the thread pitch and what not?
Old Sep 2, 2012 | 10:04 PM
https://landroverforums.com/forum/di...or-plug-41294/
DI tech section.
Old Sep 2, 2012 | 10:44 PM
L8brakelou's Avatar
Originally Posted by Spike555
For some reason I didn't check the tech section because I thought it wouldn't be in there.... That's what I get for thinking lol
THANKS!!!
Old Sep 2, 2012 | 10:47 PM
oilspotLR's Avatar
And if you bought a heater hose from auto zone then just use it. I use heater hose from autozone for heater hoses. Just make sure it is HEATER HOSE and not just rubber hose.
Old Sep 3, 2012 | 08:51 AM
You might also consider up-grading to a bronze plug like many of us have on both diff fill plugs and your radiator plug.
British Parts of Utah has them.
Attached Thumbnails Radiator bleed screw... Son of a *****-brass001-013340.jpg
Old Sep 3, 2012 | 09:47 AM
oilspotLR's Avatar
Wrap the plug with teflon pipe tape to keep the threads from "sticking" if you ever have to unscrew it again.
Old Sep 3, 2012 | 01:20 PM
antichrist's Avatar
It's BSPP. An NPT plug will bugger the threads.
$3.99 at Rovahfarm. You should have it in one to two days.
http://search.cartserver.com/search/...ERR4686B&go=GO!
Old Sep 3, 2012 | 08:12 PM
L8brakelou's Avatar
Well jacked the battery side of the truck up and bleed the system and put the plug I found in. Then I decided to check this thread again and realized I put a npt plug in there. So i decided to take it for a test drive and it is leaking a little from the plug.
So next question do I need to put a lot of tape in that or about two passes? Also if the truck is cold can I take this plug out and swap it or put more tape on it and put it back in or do I have to bleed it all again?
Old Sep 3, 2012 | 08:35 PM
You only need to bleed it if the system is drained.
2 wounds of tape should be good.
Old Sep 13, 2012 | 09:10 PM
L8brakelou's Avatar
Well I got the replacement screw from Rovers North and have been driving around and it still has some coolant coming out from around the screw...
