Deglazing/honing
I think I am going to go ahead and order my parts with the plan of following the old manual with a cross-hatch. As a related question, anything you guys think I am missing given the engine is fully apart? Or anything I probably don't need to save some money? Priced out at AB but would be interested in other sources if anyone has recommendations. Total with shipping comes to $1,682.
- Main bearings, rod bearings (STD)
- Oil pump w/ gasket
- Piston rings
- Cam + lifters + new cam bearings
- Timing chain set w/ gaskets
- Front and rear main seals
- ARB main bearing stud kit
- Rear cam engine plug
- Block freeze plugss
- Main bearing side bolt seals
- Head gasket kit w/ bolts from AB (includes all top end gaskets I think). Likely have some gasket duplication in my list but playing it safe than sorry unless someone confirms.
- New thermostat and gasket
- Piston rings
Yes
Have read this is useless to replace unless you know for sure it's broken
- Piston rings
Yes
Same as oil pump (except bearings) if you still want to replace, aftermarket Crower Cams are cheaper than stock IIRC.
Yes, I did
Yes
Not needed
Yes
Probably not needed, but cheap so I did mine as well
Comes with head gasket kit
Obviously yes. Lol
Yes, but gasket comes with kit as well.
Yes
- Piston rings
Yes
Yes, I did
Yes
Not needed
Yes
Obviously yes. Lol
Also, I bought all of my stuff from rovahfarm except 1 or 2 things
- Piston rings
- Piston rings
I can do all of this delivered for under $1000
Joemamma1954 (05-05-2016)
Do I need to replace connecting rod bolts? I knew you did for main bolts but the overhaul manual doesn't say to discard the rod bolts... But they show on RovahFarm as "Do not reuse"
Also what is the difference between a "floppy" and a "stiff" chain in terms of application. They are both listed on Rovahfarm and both show as applicable to a D1.
Where do ERR3330 and ERR3331 go? And how many do I need of each?
Front and rear oil seal recommendation: All-makes vs Carteco?
Can't seem to find main bolts on RovahFarm... Does anyone know a P/N? Checked to AB for a P/N but they only sell ARB as far as I can tell.
