Gonna Jinx myself here!
Old Dec 12, 2011 | 06:34 PM
Discolife's Avatar
Default Gonna Jinx myself here!
Ruby is running tip top, I still have the knocking tapping sound at cold start up, I am thinking this sound is lifters pumping up.
Anyway, it looks like I am getting some spring perches for a nice and quick 2 inch lift.
Old Dec 12, 2011 | 09:09 PM
With your oil, shouldn't take long. But oil may not make up for low oil PSI. Might want to do mechanical PSI test if you have not done that, or have not fitted a gauge.
Old Dec 12, 2011 | 09:13 PM
Discolife's Avatar
OIL PSI is perfect tested it about two weeks ago.
Old Dec 12, 2011 | 09:25 PM
So how long for lifters to pump up?
Old Dec 12, 2011 | 09:30 PM
Discolife's Avatar
15 seconds for the noise to disappear.
Old Dec 12, 2011 | 09:36 PM
s10lowrider1994's Avatar
Spring perches huh? Haven't seen those yet, if you don't mind me asking where do you get them and how do they work?
Old Dec 12, 2011 | 09:40 PM
Discolife's Avatar
buying them from a club member, will let you know as I was told they just install under springs and they set her perfectly,, dont know yet will inform ater
Old Dec 12, 2011 | 10:34 PM
fishEH's Avatar
Those sound like spring spacers. They actually install under the bottom spring perches. It is a quick lift. You're downtravel limiting factor will end up being your swaybars or shocks. But they're a good start to run larger tires.
slanginsanjuan
Jul 19, 2012 10:38 AM
B@tt
Oct 20, 2008 11:39 AM
JMNICK
Sep 23, 2008 02:39 PM
disco12
Jun 13, 2006 07:04 PM
HorizonDesire
May 8, 2006 03:38 PM
