Starts and then dies after a few
Old Dec 13, 2011 | 02:00 PM
bubba_78363's Avatar
Default Starts and then dies after a few
Hey Fellas,
I have this 95 DIscovery that I am trying to get right for my daughter. Newest issue is that it will start up just fine, but after about 2mins it will just die. Doesn't stumble it's just off. It will crank over just fine afterwards, but doesn't light-off. I pulled the #1 plug last night after it did it and had no spark, but on second attempt within minutes I had spark and my teeth where chattering. Put plug back in started and ran for a good 5 minutes no issues. Went out this morning to drive around before my daughter took it on the maiden voyage to school, and before I got all the way out the garage same thing...died. So I went and bought another wire set for plugs and just swapped out dist/coil and it started right up, but again only for about 2min then died. Local parts store doesn't have coil on shelf so that's why I got wires to try first. I also haven't been able to download RAVE manual because at first CD wasn't big enough, and now I just got back from buying blank DVD's cause I didn't read the package so gotta go take em and swap for CD. ANyone have any insight? Thanks
Matt
Old Dec 13, 2011 | 02:22 PM
EricTyrrell's Avatar
Save yourself some cash and mount the RAVE ISO file using Virtual CloneDrive.
SlySoft Virtual CloneDrive
Old Dec 13, 2011 | 08:30 PM
2 things come to mind.
Amplifier Module Relocation Kit | Land Rover Engine Parts at RoverParts.com
And the coil.
Coil - Distributor Ignition | Land Rover Engine Parts at RoverParts.com
Old Dec 14, 2011 | 11:25 AM
Thanks Spike and Eric for the suggestions. I ordered a coil, and should have it in a few days, but just might go ahead and pick up the amp for a rainy day. Funny thing is last night I drove the darn thing for a good 30mins without a single hiccup. Freaking gremlins...
Ad!
Aug 18, 2021 07:30 AM
Range Rovin
Jun 8, 2012 11:04 PM
bambam84105
Mar 20, 2012 02:39 PM
mapesw
Sep 30, 2010 03:34 PM
noyz25
Freelander
Jan 15, 2010 06:01 AM
