Motor Mounts
Old May 18, 2012 | 11:52 PM
FlyingZebra34's Avatar
Default Motor Mounts
Hey everyone, I own a DII but one of my friends has a DI and his motor mounts keep breaking on him. We do lots of rock crawling and technical runs so lots of torque in 4L with the CDL engaged.
SOOO .... we are thinking of installing solid metal mounts. How do you think they will perform. Also if anyone knows of any tougher mounts that the stock ones that might help.
Old May 19, 2012 | 08:26 AM
Which mount is he breaking and did he replace them all or just one? Get in touch with Rob at M.I.T., 303-679-1610, he makes a great set of H.D. D1 motor mounts.
Old May 19, 2012 | 11:47 AM
hilltoppersx's Avatar
the jag mount, forget the rest buy the best.
Jaguar Engine Mount (XJ12 XJS) - URO Parts JLM1010 | FCP Euro
Old May 19, 2012 | 12:17 PM
Banzai Jimmy's Avatar
You would consider this one better at not breaking than M.I.T. mounts or QT mounts on a rock crawling rig? Do tell...
I too broke many stock style mounts doing rock crawling and such, and finally went to QT mounts for the engine and using stock style (for now) in the back. I wasn't aware of M.I.T.'s mounts (MIT Automotive - Evergreen's only Land Rover and BMW Service and Repair Facility) when I bought the QTs - would have liked to check his out first (since he's local to me).
Old May 19, 2012 | 09:52 PM
fishEH's Avatar
I have a brand new set of these for sale. I highly recommend them and use them myself. I run lots of trails in 4LO with CDL on too.
I don't doubt he keeps breaking stock motor mounts. AllMakes makes them and AllMakes makes crap rubber components. The Jag mounts are solid and proven. And you can get them for $35 shipped.
Old May 19, 2012 | 11:36 PM
EricTyrrell's Avatar
I have Allmakes mounts and the stud runs all the way through the rubber so they really only work on compression. In this case the quality of the rubber shouldn't affect their pull strength. You'd have to break the stud or pull one of the nuts off to break one.
Old May 20, 2012 | 07:37 AM
fishEH's Avatar
Ummm, you realize the rubber is being compressed. So when that rubber fails(which it will because its AllMakes) it will no longer be under compression. Also, what makes you say the stud runs all the way through? I know for a fact the factory mounts were NOT stud through.
Old May 20, 2012 | 08:11 AM
I'm not saying these don't suck. They do suck.
I'm not saying the genuine mounts are stud through. I'm saying the Allmakes are stud through because I pulled the stud out to see.
Old May 20, 2012 | 09:09 AM
That's weird. Never seen one made with the stud through (unless it was a homebrew mount)... and I was running (and replacing) AllMakes mounts. Those Allmakes didn't last long enough to make them worth buying.
I thought about going Jag mounts, but just wanted to be done with it all. QT mounts took care of that, but they do transfer some vibration (worth it in my book). Also, in my case, they did push the engine up a bit higher than the stock height. I trimmed off the front portion of the fan shroud to clear the alternator pulley and belt.
Old May 20, 2012 | 12:04 PM
fishEH's Avatar
The Jag mounts push up the engine just a bit too. I had to shim the fan shroud up a little to clear the alt.
