SRS light Flashes /Trailer Warning Light Always ON
My SRS light flashes 2-3 times when I use the turn signal (both ways) and then goes away. It also lights up very faintly from time to time. Another issue I have is the trailer warning light is always on.
I recently had issues with the radio not switching on and thought it might be related. Turns out it was a bad relay. The radio amp also wouldn't turn on. It turns out the amp was dead, so I bypassed the amp since I already had an aftermarket radio installed.
Anyway, I just got it back from the shop that replaced the fuel pump. The mechanic took it for a spin after putting the new pump in, turned it off and ended up breaking the key inside the ignition lock cylinder. They pulled the ignition out and cleaned it up. It turns better than it did before, but I didn't have these issues until now. I just thought I'd provide that back story to see if it sparked any ideas.
Let me know what you guys think.
cipher982
11-09-2019 11:22 AM
