Throttle Sticking And Cruise Control Issue.
Old Oct 9, 2010 | 08:11 PM
Spencerfitch's Avatar
Default Throttle Sticking And Cruise Control Issue.
Truck drives fine but sometimes the the throttle gets suck open a little bit and the engine will idle rough or high. It sticks around value 19 and totally closed is value 14 on my scangauge. I tried some graphite spray but didn't get in the side under the TPS yet. I have noticed if I use my foot to pick up the gas pedal it returns to 14? I have both springs in the throttle dealio.
As for the cruise controll I use the cc STUPID amounts. I have been noticing it isn't engaging sometimes unless I turn off the cruise controll button and then turn it back on. Does this sound like the vacuum pump or the relay? And how do you check the vacuum pump?
Old Oct 10, 2010 | 08:47 PM
I see how it is.
Old Oct 11, 2010 | 09:08 AM
Lube the throttle springs and cable with silicone spray.
If it continues to stick it may be a chaffed throttle cable.
Pulling up on the gas peddle is the key phrase.
Old Oct 11, 2010 | 09:11 AM
What do you mean by,"I see how it is?"
Have you tried cleaning the t/body and the IAC? You may have 2 separate issue, cruise being one and throttle being the other.
Old Oct 11, 2010 | 09:14 AM
okdiscoguy's Avatar
I did a write up on cruise issues somewhere. Has the pin-outs and what they are supposed to read. I also took the ECU apart and r-soldered the connections on mine. Had the same issue as the window lift ECU. Try taking it apart and checking the solder joints...
Old Oct 11, 2010 | 09:29 AM
XCELLER8's Avatar
IMO I would replace the throttle cable.....before it leves you stranded or sticks permanently open . I'm sure you know this already but according to the service manual the throttle plate is completely closed @ idle and the air is controled by the IAC. So ...maybe a sticking cable was part of your idle issues earlier..just a thought. A new cable is only $35.00....fairly cheap insurance.
Old Oct 11, 2010 | 05:47 PM
[QUOTE=XCELLER8;203354]So ...maybe a sticking cable was part of your idle issues earlier..just a thought. /QUOTE]
negative.
i figured the issue out. I must have been under the hood and saw the little black nut that is threaded to the throttle cable was loose and tightened it. Today I decided to quit being lazy and popped the hood, found that it was the issue, loosened it and all is well now.
Old Oct 11, 2010 | 10:18 PM
okdiscoguy's Avatar
https://landroverforums.com/forum/sh...ghlight=cruise
ClayinSA
Nov 29, 2017 10:15 AM
focusontheworld
Nov 4, 2012 01:16 AM
jgalderman
Jul 24, 2011 05:52 PM
southfloridadiscoII
Jun 28, 2009 11:03 PM
Camdisco24
Mar 16, 2008 08:43 PM
