axle problem?
Old Oct 10, 2010 | 08:08 PM
97disco2007's Avatar
4th Gear
Default axle problem?
I replaced the left front axle and transfer case on my 97 disco back in June. Now I have gear oil coming out from somewhere.
Old Oct 10, 2010 | 08:33 PM
tweakrover's Avatar
I have oil leaking too, you are going to have to be a little more specific.
Old Oct 10, 2010 | 09:36 PM
NiteTrain's Avatar
when you replaced the axle shaft did you replace all the seals and gaskets in there?
Old Oct 11, 2010 | 07:13 AM
Long Haul's Avatar
Did you use gear oil or the one shot grease when you filled the swival *****?
Old Oct 11, 2010 | 08:34 AM
okdiscoguy's Avatar
Gonna have to be more specific....
Old Oct 11, 2010 | 09:08 AM
Before you go any further, be a lot more specific, your thread is a waste of our time with out specifics.
Old Oct 11, 2010 | 07:08 PM
4th Gear
Default sorry guys, let me rephrase that
Let me start over....I had the axle and transfer case replaced in June with used parts...the only thing he put on was the axle with swivel as it came. now (after the 90 day warranty is gone, of course) i have what smells like gear oil all over my wheel... i wash it off and by the time i drive to work the next day there's more. i've babied it since i had the work done but i've got almost 190,000 miles on it so....i hope this is more specific for you, im not a mechanic, can do some engine repairs but never dealt with axles. thanks for anything you can tell me.
Old Oct 11, 2010 | 07:33 PM
discomedic4's Avatar
Sounds like a swivel ball rebuild and time to replace the seals. What was the swivel ball filled with after the axle rebuild, gear oil or the one shot packet from LR?
Old Oct 11, 2010 | 08:01 PM
4th Gear
I'm guessing the ball was filled with gear oil.
Old Oct 11, 2010 | 08:48 PM
I would say a rebuild kit from AB is in order. In the meantime you better check to see what the fluid level is like in that swivel ball. If it is leaking that badly and you are still driving it, you may start doing some damage. Maybe the other guys have a more specific idea but if you are having a problem with the seals this quickly after a rebuild then it was either done wrong or they used old seals. Either way it all needs replacing IMHO.
