Help - Timing Gear Gasket
Old Jan 15, 2012 | 08:31 PM
04BluDisco's Avatar
Default Help - Timing Gear Gasket
putting the timing gear gasket on right now after replacing gears, chain and oil pump.
RAVE says put the timing cover gasket on Dry... has anyone done this, and how has is worked long term? Asking because I generally put some RTV on there...
Thanks
Old Jan 15, 2012 | 08:42 PM
94svt50's Avatar
I did mine according to the rave. It's only been 200 miles since but, so far so good. From what I have heard it is extremely important to not exceed the stated torque on the bolts. The gasket can pinch and leak coolant internally if overtightened.
Old Jan 15, 2012 | 08:57 PM
04BluDisco's Avatar
thanks!
Old Jan 15, 2012 | 10:15 PM
boris_gti's Avatar
I did the same thing. Plain gasket nothing on it. About 3000 miles and no leaks.
A5scott
Jul 11, 2015 07:25 PM
outdoor7or24
Dec 22, 2014 09:31 PM
Martin Rodriguez
Feb 25, 2014 08:55 PM
mcneal
Nov 25, 2008 08:10 AM
