04 Discovery Vibration Found Now What To Do
I have been a long time reader of this forum and think it is the best Land Rover forum on the web. I have had a 97 DI for the last 6 years and have moved into a 04 just recently and working out a few bugs. It is finally time to make a post as I have no idea of the best option for my situation. My discovery 04 had a vibration that started about 55 and the worst at 65 and seemed to smooth out at 70. I searched and searched and have tried many things including removing front drive shaft ( shaft is new ), new tires, and new rear roto flex and u-joint nothing helped. One last test was to remove the rear shaft and test for vibration and with shaft removed it is smooth as silk.
My question is what to do. I have a few options but want to do this right. I could send shaft to a local shop and have it check and balanced
I could buy a shaft at the dealer
I could buy a shaft from Atlantic British
I could buy a used shaft from a local Rover salvage yard
I would appreciate and opinions.
Thanks
Jon
Thanks
Jon
Do not chance damaging your tranny, rotating the drive shaft.
If anything remove it, engage your CDL to H lock and drive. If the problem is gone then either rebuild it if you know how or go to someone like Bill Davis at Great Basins Rovers in Salt Lake City, he has over 30 years of drive line related experience and offers 2 different drive shaft replacement.
If when you look at your drive shaft and it only has 1 grease fitting then get rid of it any way cause they all fail at some point and you don't want to loose a tranny at the same time when it does go south.
Thank you for the replies! I sourced a thought to be good rear shaft today and gave it a shot. The vibration is still in the vehicle but not as bad. This vibration is gone with rear shaft removed. I'm thinking about pulling this shaft out and sending it out to the local drive shaft shop and have it check.
I'm willing to try just about anything at this point so all ideas are welcome.
VIBRATION FOUND!!!!! Good news I have found the rear diff centralizing pin is bent. I called the dealer and they do not know what I'm talking about. This centralizing pin is the nub that sticks out of the rear pinion flange ( this part has to be removed to access pinion flange nut) and the rear drive shaft bushing rides on it. If anyone knows the part number please post it.
bosshogt
12-23-2011 10:24 AM
