1999 Discovery I HELP!!!!
Old Jul 7, 2007 | 03:12 PM
MUD DONKEY's Avatar
Default 1999 Discovery I HELP!!!!
can someone please help me? this is my first rover, and i am having a couple of problems. first thing is, sometimes it won't start. it won't do anything: no lights, nothing. then by some twist of fate, after a minute, it will start. i can sometimes go a few days before this will happen, and sometimes it will happen quite often. i read about the "spider" and after i took everything apart.............no spider! it has actually cut off while driving also.
my next question is i installed an aftermarket stereo and can't for the life of me get the engine noise out. i have tried grounding in many different places but no luck. HELP!!!!
Old Jul 7, 2007 | 04:45 PM
rphotographer's Avatar
Default RE: 1999 Discovery I HELP!!!!
sounds like a bad battery connection, I had another car with engine noise thru the radio, went to radio shack and got a filter...worked great, probably get a filter at a good automotive supply.
hope this helps
Ralph
www.ralphduke.com
Old Jul 7, 2007 | 11:45 PM
MUD DONKEY's Avatar
thanks i'll try the filter and check the battery connection. nothing i love more than electrical trouble shooting![:@]is it possible that it could be in the ignition switch? i can have power but as soon as i turn the key everything goes dead..........
Old Jul 8, 2007 | 12:33 PM
okdiscoguy's Avatar
ok, 2 questions... What year is your truck? I have a 97 and it has a common ground system running to a factory amp behind the glove box. Adding a ground loop isolator might fix your whining, but if you have this system, you will have to get a module to separate the grounds and then bypass the amp...
#2- did you have the cut-off problem before you installed the stereo? It sounds like an ignition switch to me as well, but you may want to check your inertia switch. Should be a pushbutton under the hood by the firewall passenger side, depending on year.
Old Jul 8, 2007 | 12:39 PM
okdiscoguy's Avatar
oops, just noticed the year in the title..... Check what I mentioned...
Old Jul 8, 2007 | 02:09 PM
MUD DONKEY's Avatar
it did do this before i installed the stereo. i checked the battery gound, (cleaned it, etc) and am still having the problem. i will go check the inertia switch now.
Old Jul 8, 2007 | 02:15 PM
MUD DONKEY's Avatar
its not the inertia switch. can these switches go bad? i just want to be sure i check everything before i have to spend $300.00 for an ignition control assembly, or would i just need the "electrical" part of the switch?
Old Jul 8, 2007 | 02:21 PM
MUD DONKEY's Avatar
need to add that i can "cycle" thekey about three times before everything shuts down.
Old Jul 8, 2007 | 02:22 PM
okdiscoguy's Avatar
I have heard of people having problems with the ignition switches. Not sure on a fix besides replacement. Have you checked and cleaned your positive side as well? The fact that it has just died while driving points me to the switch. Also, if it was the inertia switch, I think it should flash the hazards or something.
I am just shooting in the dark here, though. I am sure someone else will chime in with some ideas...
Old Jul 8, 2007 | 02:24 PM
MUD DONKEY's Avatar
i appreciate your help, i will go check and clean the positive terminal now also. ain't troubleshootin' fun![:'(]
