2001 disco power driver power window failure
Old 03-14-2008, 08:21 PM
bigfun's Avatar
Default 2001 disco power driver power window failure
2001 disco need helpplease. Thewindow motor in driver door makes noise but the window does not go up or down? I can move the window up and down manually very easily.I had to tape the glass in the closedpositionto keep it from sliding down andopening. Regulator? off track? easy to repair? Is the process/ instructions somewhere in a document on the web? What should I check/change? Is this common
Same truck wiper does not work when in the delay postion, the wiper stops in themiddle of the glass, obstructs vision, then eventually moves and stops in some other random position? This was like this when I bought it 6 mos ago. Is that easy to repair? What parts?
thanks,
Phil
Old 03-14-2008, 09:27 PM
Default RE: 2001 disco power driver power window failure
Nothing to check, you need a new window regulator and a new wiper motor cause the park switch is failing.
Wayne
10-02-2020 12:10 PM
RogerThatRover
06-11-2015 03:50 PM
djmitten
08-12-2011 05:12 PM
totalperformance65
05-19-2006 06:05 PM
Str8BacardiL
03-18-2006 10:57 AM
Quick Reply: 2001 disco power driver power window failure
