AC unit reading Celsius after battery disconnect?
Old 11-26-2009, 04:12 PM
robgusto's Avatar
Default AC unit reading Celsius after battery disconnect?
I disconnected my battery and need some help? Does anyone know how to change the AC in a 03 Disco from Celsius to Farenheit?
Old 11-26-2009, 04:37 PM
reytt64's Avatar
Tech Tips
Tech Tip - Temperature Calibration on Climate Control - Fahrenheit vs. Celsius
Applies To:
Discovery Series II | '99-'04
If your temperature reads in climate control reads in degrees Celsius “C” instead of Fahrenheit “F”, follow these steps to change to Fahrenheit.
  • Turn the ignition on.
  • With the climate control turned on, push and hold the recirculation button in. While holding the button in, push and hold the off button in for 3 seconds or until you hear a beep.
The display should then change to “F”. Follow these same steps to change your read-out to Celsius , if preferred.
Rey
DII LE 62K
Head gaskets, timing cover gasket, water pump gasket, 60K service, maganacore wires, brakes.
To do: u joints.
Old 11-26-2009, 06:52 PM
robgusto's Avatar
that worked. thanks Rob
Old 11-27-2009, 02:20 AM
Urban Panzer's Avatar
whats wrong with C° anyway :P
Old 11-07-2011, 06:53 PM
aarongregor's Avatar
Thanks, worked like a charm!
Old 11-12-2011, 08:57 AM
shultzie's Avatar
Thanks
bigbalu
12-04-2014 02:13 PM
BFox15
08-03-2011 06:47 PM
dkelly13
03-12-2005 12:24 PM
Quick Reply: AC unit reading Celsius after battery disconnect?
