Blinking brake light
Hi Fellers and Gals,
Its the old man again. 2000 Disco 2, 110k miles
I have a blinking brake light on the dash. The one that tells you your hand brake is on. Hit a bump turn a corner ect. I think I know the problem, hand brake needs adusted as it goes about seven clicks and should be three. Does the window switches have to come out? If they do how much more comes out before I can make adjustment?
Service manual says remove gaiter. Is that the boot on the shift lever? ( Never said I was smart.)
Shoes need tightened and then back off 1.5 turns and then take up cable . I think I have all that but some of the terms they use stump me.
I to have had dealer problems. Took it in because of three amigos, and a surging between 40 and 50mph . 1k bucks later and still surges. I am more upside down on truck than before.
Service is great as far as the people go but their mechanics are not worth what they charge for them. They balanced ( Tried to) tires new MAS, new throttle heater gasket,new drag link, and adjusted brain back to spring suspension and not air. No idea why it changed.
Love the truck feel good in it just getting so I am afraid to take it anywhere.
Sorry this is so long Thanks for your help.
Con
Con
RE: Blinking brake light
Before you begin to take your console apart and climb under the back of the truck, follow the recommendation from okdiscoguy. The sensor on the brake fluid cap can sometimes get dirty and stick. Just make sure your brake fluid is topped off and the sensor is clean of debri. If the light still keeps coming on then attempt to tighten the e-brake, and also consider that your break pads my be wearing down.
DeepBlueWater
10-15-2007 07:38 PM
