unfinished cam bearings?
Old Jan 6, 2010 | 02:06 PM
03discoman's Avatar
Default unfinished cam bearings?
my motor wont make oil pressure...
i think its the cam bearings, where can i get unfinished bearings finished or where can i buy finished 4.6 bearings
Old Jan 6, 2010 | 02:45 PM
meltdowndave's Avatar
Since you have an '03, can I assume that your oil pump is working? How many miles on your truck?
How have you check the pressure? With a gauge or just by the OP lamp?
Link to bearings: http://www.roverparts.com/Parts/STC1961.cfm
Old Jan 6, 2010 | 02:54 PM
03discoman's Avatar
i need finished bearings!!!!
oil pressure is around 15 psi at 2k rpm warm
engine has been rebuilt... cam bearing must be worn
Old Jan 6, 2010 | 03:16 PM
geotrash's Avatar
On an '03, the oil pump is the first suspect for low oil pressure, rebuilt engine or not. I don't think the cam bearing finish will matter much.
Best,
Dave
Old Jan 6, 2010 | 04:24 PM
03discoman's Avatar
new pump and new main bearing and con rods bearings... 2 different oil pumps and 3 different sets of bearings...
this is either a block issue or cam bearing issue...
does anyone know where i can get finished bearings.... install and go
Old Jan 6, 2010 | 05:09 PM
DiscoArt's Avatar
I don't think there is such a thing. Bearings have to be finished after they are installed in the block.
Old Jan 6, 2010 | 06:13 PM
What is the pressure hot and cold, at idle and at 2000 RPM's?
Old Jan 29, 2012 | 08:07 PM
2001SE7's Avatar
Default Finished Bearings
Mark at D & D Fabrications sells finished cam bearings for 4.0/4.6
Also partsrange on eBay.co.uk sells a set from RPI Engineering.
Old Jan 29, 2012 | 08:29 PM
kenk's Avatar
finished cam bearings:
Turner Engineering STC 1961 Camshaft Bearing Set
mlshelton
Audio/Visual Electronics
Mar 20, 2008 12:37 AM
crownaviation
Feb 3, 2008 04:51 PM
Greenagain
Jan 30, 2008 08:40 PM
sharp21
Engine & Internal
Dec 18, 2007 09:00 PM
jimllshiftit
Oct 16, 2007 04:11 PM
