CAN'T PULL OUT HEATER RETURN PIPE TO REPLACE "O" RING and then some
#22
We actually sell a lot of those pipes on eBay. I remember wondering why they always sold until the last HG job I did. Same experience, pipe would not release from the manifold. I ended up prying on it so much that the flange broke off of the pipe. There is no circlip or attachment for the flange, it is tack welded onto the pipe.
Also, that's some mean sludge on those rocket assemblies!!!!
#23
As per the sludge, pretty much ain't it? it is a very thick coating, I guess from many years of bad maintenance. Will tackle each side with patience, won't touch that rockers though, just changing the gaskets, but I'm cleaning the covers; if it was nasty taking the sludge out of the covers, can't imagine how hard it must be for those rockers to rock under that sludge. I guess the cleaning agent in Rotella isn't doing much! ...getting the bolts out was fairly easy, they weren't tight at all, would had probably unscrewed them with my fingers, go figure! ...no wonder it was so wet all around it.
...where do you sell them in eBay? the pipes I meant... and thanks for the feedback!
#24
...thanks mollusc, I think I'm at the "get a frikin' pry bar" stage, plus whole lot of encouragement! ;-]#
#25
On the buildup under the covers, you'll probably find that there's some coke and debris buildup around the rockers too. I would try carefully removing some of that while you've got the rocker covers off. You'll probably end up with at least some sludge coming loose and swirling through the oilways, so an oil and filter change soon afterwards would be advisable.
And when reinstalling the rocker cover bolts, Loctite is your friend! Those things come loose for no reason at all.
#26
#27
Wow. That's a sludgy head. Wow! You're having so much fun already get some studs and take them off!
On the heater pipe I've had trouble with mine, too. I ended up taking the rubber hoses off and twisting it out. But if abran has broken them, then some are truly difficult to get out so that may not work. The part that seals is farther in the intake so you probably can't harm it by levering against the flange, unless you break it.
#28
...as per the pipe, twisting was an option too -rubber hose was third thing out- but attempts only got the pipe to bend a bit insteadof twisting, so unsure, decided yo abort the twist, shout, and kept with the banging! ;-]#
...in any case, all these feedbacks I'll be putting to use when back at home after work, gotta thank wifey for lending me her wheels, for now! ;-]#
#29
...nahhh, not that much fun really! and not much of a savvy DIYer to get some "studs" and get it off; I would need to start by asking, what are the "studs" you're referring to. ;-]#
That pipe is incredible. I'd probably beat on the lower intake with a hammer, and I'm sure that would be the wrong thing to do.
#30
The studs would be replacements for head bolts. My only concern about your sludge is that it could clog other things if disturbed because it is so...awesome. So I was suggesting removing, cleaning and replacing the heads.
