Oil Pan bolts
Old Jan 24, 2012 | 06:44 PM
MrFlea1's Avatar
Default Oil Pan bolts
2001SE7 4.0 are the oil pan bolts a special thread or can they be bought at a local hardware store? I misplaced 3 bolts somewhere and believe they were swept out the door. Also The rubber "Plugs" on the rear of the oil pan that cover the torque convertor access are they available. Mine are all swelled and torn. Any information would be greatly appreciated.
Old Jan 24, 2012 | 06:56 PM
Like most things on the Rover, will most likely be metric, pull out one of the remaining bolts to take with you. Some auto parts stores have this sort of thing as well (people with BMWs drop bolts, too).
Old Jan 24, 2012 | 07:40 PM
MrFlea1's Avatar
Funny I still think they put way to many bolts in anyway........LOL
Old Jan 24, 2012 | 07:52 PM
If you had pan off, did you replace O ring on the oil intake screen pipe?
Old Jan 24, 2012 | 08:31 PM
MrFlea1's Avatar
Yes I did Also doint the "O" rings on the cooler lines too ...any thoughts on the convertor access hole plugs??
Old Jan 24, 2012 | 10:03 PM
04BluDisco's Avatar
Are folks typically using a thread locker on the oil pan bolts? I didn't when I replaced, but looks like they may have previously at the factory....worst case scenario, I can pull them out and put thread locker on them one at a time...
I dont remember seeing it in the RAVE
Old Jan 24, 2012 | 10:20 PM
lordmorpheus's Avatar
My thoughts on those plugs: If they are intact, and in place, leave them as they are. Chances are, if you remove them, you are never going to get them back in place, because they have probably swelled several millimeters in diameter due to oil leaks. New plugs can be had from the dealer at the cost of about $12 each (from memory)
Wouldn't the bolts be SAE given the block is a 1960's GM reject?
Old Jan 25, 2012 | 10:58 AM
MrFlea1's Avatar
As a mater of fact they are 5/16 coarse to be exact. Thats funny tho because all the attaching bolts are for the add ons are mertic. Thanks for the heads up !!
robersonb
Jan 2, 2013 01:43 PM
0304Disco
Oct 15, 2012 05:16 PM
modelwerks
Oct 13, 2005 05:39 AM
jconway
Engine & Internal
Jun 20, 2005 03:22 PM
jconway
Jun 20, 2005 03:21 PM
