Death wobble still! Any ideas??
03 DII, 70k. I have had the death wobble for a while. Pronounced when hitting bumps. Does not do it on braking. I put an OME Steering stabilizer on, no fix. This weekend I had the driveshaft rebuilt with greasable U joints, no fix...but needed to be done anyway. Put 4 brand new Nitto Terra Grapplers on, still no fix. What can I narrow it down to?? Thanks!
RE: Death wobble still! Any ideas??
Jack up the front end and check the ball joints (I think Rover's have those) for play. Grab the top and bottom of the wheel and shake it back and forth. Any play could cause it to wobble while driving. Tie rod ends could also be worn. Really anything that could wear out suspension wise should be checked. Good luck.
Cheers,
Pete
Cheers,
Pete
