Death wobble still! Any ideas??
Old Sep 2, 2008 | 12:44 PM
pelias's Avatar
4wd High
Default Death wobble still! Any ideas??
03 DII, 70k. I have had the death wobble for a while. Pronounced when hitting bumps. Does not do it on braking. I put an OME Steering stabilizer on, no fix. This weekend I had the driveshaft rebuilt with greasable U joints, no fix...but needed to be done anyway. Put 4 brand new Nitto Terra Grapplers on, still no fix. What can I narrow it down to?? Thanks!
Old Sep 2, 2008 | 12:58 PM
NiteTrain's Avatar
Default RE: Death wobble still! Any ideas??
Do you have death wobble or just a vibration? Death wobble usually happens after you lift a vehicle. When you hit a bump your wheels will uncontrollably go left to right several times and you can barely hold onto the steering wheel.
Old Sep 2, 2008 | 12:59 PM
There is another guy on here who has the same problem, you guys should talk.
I would just take it in to a suspension shop and have them look at it.
Old Sep 2, 2008 | 03:10 PM
Switzer's Avatar
Jack up the front end and check the ball joints (I think Rover's have those) for play. Grab the top and bottom of the wheel and shake it back and forth. Any play could cause it to wobble while driving. Tie rod ends could also be worn. Really anything that could wear out suspension wise should be checked. Good luck.
Cheers,
Pete
Old Sep 2, 2008 | 07:50 PM
snorlax's Avatar
This happened to me twice, both times the tire pressures were too high.
Old Sep 2, 2008 | 07:57 PM
NiteTrain's Avatar
I have a fairly bad vibration at 51-52mph. 0-50 nice and smooth, 52+ nice and smooth. I assume it's just out of balanced tires, but I have never seen a vehicle with such a bad vibration only at a certain speed.
Old Sep 2, 2008 | 11:11 PM
roverguy7's Avatar
youre going to need a new drag link and track rod, it has your tie rod ends on it, and they go bad every now and then, resulting in exactly what you have... also, make sure that your steering box is correctly mounted, seen that a few times too
Old Sep 2, 2008 | 11:42 PM
NiteTrain's Avatar
roverguy7, are you talking to me or original post?
Old Sep 2, 2008 | 11:45 PM
roverguy7's Avatar
orriginal post... is your in the steering wheel or the body of the truck?
Old Sep 3, 2008 | 12:14 AM
NiteTrain's Avatar
ORIGINAL: roverguy7
body, It's odd how it only does it at 51-52mph then rides so smooth the rest of the time.
