Explain the sunroof drains.
Old May 2, 2010 | 05:55 PM
Spencerfitch's Avatar
Default Explain the sunroof drains.
So Im trying to get rid of my wet passenger floors and just uncloged the ac drains. They were clogged.
Now, I would like to check the sunroof drains, but where do they exit? Where do they usually clog? They clog under the headliner? Id like to not do that for now.
Old May 2, 2010 | 06:01 PM
greg409's Avatar
Can you do a search "sunroof drains"? -- there's 62 threads
luck,greg
Old May 2, 2010 | 07:27 PM
sorry I BEEN doing google searches and all I find is people saying that there is a sunroof drain tube.
Old May 2, 2010 | 08:42 PM
greg409's Avatar
No, I meant here - just on this forum alone there's (62) threads, (61 excluding this)
(scroll up to the top brown band on this page, in the center, "search")
I'm a lazy bastard, I hate typing (honest)
luck,greg
Old May 3, 2010 | 01:11 PM
Sorry but I went through just about every thread. All they said is to remove the headliner. I dont think its leaking from my headliner as my headliner is dry. All I wanted to know was where the tubes exit the vehicle..
Old May 3, 2010 | 01:21 PM
j.dstasio's Avatar
On my Disco2, the rear sunroof drains exit behind the rear brake lights. Pull the light housings off & you will see the tubes. I am still trying to figure out where the front sunroof drains to. I somewhat remember reading they were near the front wheel wells, but I have not seen them myself.
From what I read there is a connector on the sunroof unit itself that sometimes cracks & the tube becomes disconnected. You will have to pull the headliner down some to check this though.
HTH
Old May 3, 2010 | 01:23 PM
yloDiscoII's Avatar
Should drain directly forward of the front doors, straight down to the ground. Not sure if it's the same on a DI as my DII, but check the drains in front of the windshield on the outsides of the "trough." Mine were clogged with pine needles, leaves, etc...See attachment for what I'm talking about...
grandkodiak
Oct 7, 2022 02:39 AM
TOM R
Jul 26, 2018 11:41 AM
nynole
Feb 26, 2008 06:04 AM
traffictech870
Mar 23, 2005 11:45 PM
