Frequent Stalls, Running Rough, No Codes
Old 09-15-2013, 01:50 PM
bbaileyii's Avatar
Red face Should have started with the fuel pump relay...
So at 125,000 miles I replaced the head gaskets. While I was doing that I figured it was a good time to replace a bunch of stuff.
New Head gaskets
New Water Pump
New Thermostat
All new hoses for cooling system
All new plugs and wires
New fan & viscous clutch
All good, right? Well about a year later it started stalling and running rough, so I didn't drive it as much... I decided after about a year of not much use to sell my Nissan truck and use the Land Rover as the daily driver. That meant it was time to fix that stalling thing...
I started with fuel injector cleaning and gas additives. Didn't work.
I put a new Crank Position Sensor (CPS). Didn't work.
I put a new MAF. Didn't work.
I took off the K&N and put the stock air cleaner on and then replaced the MAF again. Didn't work.
I replaced the CPS again and this time fixed the oil leaks from the valve cover gaskets. Didn't work.
Replaced the Cats and all 4 O2 sensors. Didn't work.
I put in a new fuel pump. Didn't work.
I put in a new fuel pump relay. Worked!!!
Fuel pump relay = $14.95
All the other stuff = about $2000.00
Wish I would have tried the fuel pump relay sooner, but wow does she run great now!!
Thanks to everyone for all the input and feedback. I fixed several other annoying things while I was trouble shooting the stalling that I found fixes for here on the forum. Really awesome!
Next I'm going to tackle the 3 amigos!!!
Thanks again everybody.
Bill
dillhole
02-20-2020 02:30 PM
parke
08-25-2014 09:55 PM
Dane!
06-16-2014 01:25 PM
G,Demro
01-20-2012 09:06 PM
SurfRat
01-16-2012 10:17 PM
Quick Reply: Frequent Stalls, Running Rough, No Codes
