Fuel pressure drops to zero after shutoff, hard to start warm.
Old 04-04-2007, 07:21 PM
atikovi's Avatar
Default Fuel pressure drops to zero after shutoff, hard to start warm.
I just got this '96 Discovery 5-speed with 166K and I starting to work on the bugs. It's hard to start when warm, as in, I crank a few seconds, stop, crank again, stop, and crank again and usually it starts the third time. I hooked up a fuel pressure gauge and noted the pressure at idle was 30 psi. but when I shut the engine off the pressure dropped to 0 within 10 seconds. Thats the problem. What should I check as the cause? I replaced the filter and I don't think it's leaking injectors.[/align]
Old 04-04-2007, 11:20 PM
okdiscoguy's Avatar
Default RE: Fuel pressure drops to zero after shutoff, hard to start warm.
sounds like a leaky injector to me... I think if you pull the plugs and lookfor a dark one, it will show you which one is leaking. Unless there is fuel leaking out of the line somewhere....
just my thoughts.
Jason
Old 04-04-2007, 11:27 PM
shagybruce's Avatar
could also be the check valve in the fuel pump.(supposed to stop fuel from draining back into the tank.) or a fuel pressure regulator.
Old 04-05-2007, 09:32 AM
atikovi's Avatar
There is no smoke on startup so it can't be leaking injectors.Can the fuel pump check valve be replaced by itself?
Old 04-05-2007, 12:29 PM
I would also say it is the fuel pressure check valve and if that is the case, you will have to replace the pump.
Mike
Old 04-05-2007, 06:32 PM
atikovi's Avatar
Just installed a new fuel pump. Now after turning the engine off I still have over 25psi fuel pressure 30 minutes later. Problem solved.
Old 03-27-2016, 08:30 PM
3crguy@gmail.com's Avatar
4wd High
How did you check fuel pressure? Sorry having somewhat similar issue..
Old 03-27-2016, 08:45 PM
jamieb's Avatar
Might not get a reply from the original poster. It's a 9 year old post and the guy hasn't posted since 2014.
Old 03-27-2016, 08:51 PM
4wd High
Lol yeah i saw that right after i sent reply.. ��
Old 03-27-2016, 09:05 PM
jamieb's Avatar
Somebody might chime in. I can't recall where to tap in to get fuel pressure.
raptorial
02-29-2020 02:02 PM
ilund
08-19-2013 10:11 AM
MC04DII
03-31-2013 03:34 PM
robertnsmith
04-06-2010 05:59 PM
jdelp
03-30-2008 11:28 AM
Quick Reply: Fuel pressure drops to zero after shutoff, hard to start warm.
