clinking noise after shutoff
Old Mar 29, 2008 | 03:53 PM
jdelp's Avatar
Default clinking noise after shutoff
My truck is running great, just finished all the 60k service stuff including new plugs, wires and intake manifold gasket. Everything seems fine, but now after shutoff for a few minutes I'm getting a loud, metal on metal "clinking" that wasn't there before...at least I don't think it was. Is this normal?
[align=left] [/align]
Old Mar 29, 2008 | 04:46 PM
Default RE: clinking noise after shutoff
No, it is not normal, when exactly do you hear it and can you be more specific as the area it is coming from?
Old Mar 29, 2008 | 05:25 PM
I think what you are hearing is the exhaust cooling off. I know the sound that you are talking about, probally WAS there before but you are more concious of it now because you just had work done.
Old Mar 29, 2008 | 05:54 PM
jdelp's Avatar
I hear it a few times a minute for about 3-5 minutes after turning the motor off, and it does sound like the exhaust manifolds cooling off. It's coming from the back of the motor near that area, so it could be just that. Any other thoughts though?
Old Mar 29, 2008 | 06:24 PM
As Spike has already mentioned, your exhaust system is cooling down, could be a heat shield starting to fail.
Old Mar 30, 2008 | 10:22 AM
jdelp's Avatar
Hmmm, okay. Well, if it is the heat sheild, how exactly does it fail? Isn't it basically just a piece of metal? Can it be repaired (welds or something) or does it need replacing?
Old Mar 30, 2008 | 10:28 AM
It is usually multi layered material, some time the material separates or the mounts break.
Old Mar 30, 2008 | 11:20 AM
jdelp's Avatar
Thanks mike, I'll check and see if I find anything. I'm wondering, if that's the culprit - would spot welding it or pop riveting be an option?
Old Mar 30, 2008 | 11:28 AM
Just take it to your corner muffler shop, they deal with loose heatshields all the time.
I dont think that is what it is, but they will look at it for you.
atikovi
Mar 27, 2016 09:05 PM
ConradLeo
Jun 22, 2013 09:02 AM
MC04DII
Mar 31, 2013 03:34 PM
brooksa
Jul 19, 2009 12:06 PM
newBrover
Oct 16, 2007 05:57 PM
