Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Discovery II
Register Forgot Password?
Search
Old 09-29-2010, 12:35 AM
Member
Default Fuel Tank Skid Plate.. in 45 min.
If you have spent any time under your Rover you know the factory skid on the gas tank is not really much of a skid plate at all as it covers only about half the tank.
So if you have a spare 45 min why not swap it out with a really nice bit of kit from RockArmor. Its a 1/4 inch think full aluminum skid and worth its weight on gold if you plan on getting on the rock, or for some people tree stumps.
BEFORE YOU START RUN YOUR TANK AS CLOSE TO EMPTY AS YOU CAN...this makes it a heck of a lot lighter!
I ordered mine online and had it in about 4 days thanks to Mr UPS man. The first thing did was put some WD40 on the 4 bolts that hold the factory skid on the night before i planned on staring. You are going to reuse these to be careful with them.
Step one, see how small the factory skid really is..
Click the image to open in full size.
Step 2 is unpack the monster from the box
Step 3 put a support under the left side of the tank,
the frame will support the right side.
Then remove the 2x 13mm rear bolts and the 2x 15mm front bolts that hold the factory skid on.
Note the WD40 from the night before.
With the slids side by side you can see what was not covered by the factory!
I used an old tie down strap to support the tank from the two rear tow hooks, this meant i could remove the jack and block of wood supporting the tank to allow me to put the new skid in. Pass them over the frame as i did and it works great.
remove the jack SLOWLY and the tank should not move.
Next clean up your old mounting hardare if you have to and add a drop of lock tight to the threads.
then its simply line up the holes on the skid plate with existing mounts and reattach using the old hardware. Once done,pull out the old strap and this is what you end up with..
A fully protected tank, and it looks super cool too!
If you in the market for one give the guys at Texas Land Rover Service / Underground Rovers a call (contact info below) and all in with shipping this was under $200 bucks.Money well spend if you ask me.
I had never dealt with this company before but they answered my questions quickly, provided a great product at a great price and the fit and quality were really first class and so i though i pass this on to anyone thinking of getting one.
Dave
you can contact them here.
Texas Land Rover Service-Underground Rovers
15115 San Pedro (U.S.281 & Brookhollow)
San Antonio, TX 78232
210.496.3246
210.393.7778
www.undergroundrovers.com
www.texaslandroverservice.com
www.autogroupofsanantonio.com
__________________
'99 D2 with 150k, Added CDL, 3 inch OME lift, Superwinch X9, SD rack, Snorkel, etc etc
Old 09-30-2010, 09:19 PM
oysterhead's Avatar
Senior Member
Very nice.
__________________
2004 D2 S
3" OME, 32" Wrangler A/Ts, STI wires, EBC pads
Repairs since 4/09: head gasket and rebuild, throttle plate bypass, shuttle valve, front driveshaft
Old 10-01-2010, 12:36 PM
DiscoWest's Avatar
Senior Member
Excellent write up, checked their website and the rock sliders look nice as well, and priced well!
__________________
DiscoWest
2002 Land Rover Discovery Westminster
4.6L swap at 68751miles
Magnacore 8.5mm wires
Rovertym 2" springs, retainers, adjustable panhard bar, HD stainless steel steering linkage, front crossmember spacers
Bilstein 7100s (+2"), Bilstein steering damper
Hankook Dynapro MT 275/65R18s
Brush guard
Hella FF1000s
Inline thermostat mod
77k
Old 10-01-2010, 02:27 PM
tweakrover's Avatar
Senior Member
they have the terrafirma kits for $425
__________________
'94 disco 170,000miles, 2" terra firma med duty lift, 245/75-16 wild country xtx tires
The epitome of British Engineering
Tags
2002, aluminum, close, fuel, gas, gastank, land, landrover, lr3, lr4, plate, plates, remove, rover, skid, tank
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
Emails Backup
