Heated Windshield
Heated Windshield
The driver's side of my heated windsheild doesn't seem to work.
I unplugged both sides and tested to see if there was power going to the windsheild. There is on both. Also, both fuses are NOT blown.
Also, I tested continuity on the windshield. I hvae continuity. Any ideas?
Thanks
Thanks
RE: Heated Windshield
Also, does anyone know exactly how the windshield is wired?
I assume a positive strip on top, negative on bottom, and the vertical line run between them?
If the top or bottom breaks or is manufactured wrong, then the heat won't work from that point on?
What does the relay do?
Could a bad relay cause the driver's side not to work?
Question about heated windshield... dealer tech isn't answering phone, need quick answer if possible
dma3
04-04-2005 04:08 PM
