Heated Windshield
Old Oct 28, 2006 | 05:07 PM
wimp's Avatar
7th Gear
Default Heated Windshield
The driver's side of my heated windsheild doesn't seem to work.
I unplugged both sides and tested to see if there was power going to the windsheild. There is on both. Also, both fuses are NOT blown.
Also, I tested continuity on the windshield. I hvae continuity. Any ideas?
Thanks
Old Oct 28, 2006 | 05:17 PM
wimp's Avatar
7th Gear
Default RE: Heated Windshield
Also, does anyone know exactly how the windshield is wired?
I assume a positive strip on top, negative on bottom, and the vertical line run between them?
If the top or bottom breaks or is manufactured wrong, then the heat won't work from that point on?
What does the relay do?
Could a bad relay cause the driver's side not to work?
Chuck in MA
LR2
Jan 29, 2014 04:11 PM
dsmtrain
Oct 2, 2008 07:23 PM
MeHeadHunter
Jan 19, 2008 08:46 AM
BostonBB
Oct 9, 2007 05:32 AM
