Liner Failures Explained
Hey guys, since this is a prevalent issue on Discovery as well, I figured I should post it. I found this great article that explains that liners can't slip on the newer engines because they are held in place. Instead the block cracks most likely due to the head bolt's stress on the block. Here is the article: http://robisonservice.blogspot.com/2...-failures.html
