Major Service.
Old Dec 19, 2011 | 08:47 PM
  #51
rimasco's Avatar
woahh.. not all at once..
Old Feb 23, 2012 | 07:46 AM
  #52
vserduchka's Avatar
I just did the most elaborate oil change ever...
Poured a quart of ATF into the crankcase and drove the car about 6 miles.
Drained the oil (no chunks, but very dirty).
Refilled with 5 Qts. Mobil 5W30 and a bottle of Gunk engine flush. Let it idle for 5 minutes.
Drained the oil (not nearly as dirty as the old oil so I was a bit disappointed that I spent an extra $25).
Replaced the oil filter with a Mobil 1 filter and filled up the crankcase with Mobil 1 5W40 full synthetic.
A bit ****, I know, but at least I have the peace of mind of knowing that my engine is clean.
My D2 now runs noticeably quieter and smoother (at least in my head it does).
Old Mar 2, 2012 | 03:50 PM
  #53
seadevils21's Avatar
6th Gear
Guys, I'm new to the Rover World but love my 03 Disco. I have 95,000 miles on it and I keep having the SERVICE ENGINE SOON light come on and off any idea where i should start 1st???
Old Mar 5, 2012 | 05:02 PM
  #54
innzane's Avatar
Hey, if you guys kick this jerk zane, above off the forum, can I have his user ID?
Old Mar 22, 2012 | 11:18 AM
  #55
johndreaney's Avatar
Default I agree can we get some posts on how to do these
Originally Posted by camgkh
Disco mike can you please explain how to flush and change some of theses fluids?
in detail. i need help
I concur - it would be great if we had links to posts explaining the best ways to change all these fluids.
Old Mar 23, 2012 | 06:10 AM
  #56
drowssap's Avatar
you could try using the search button, there are sticky and link as well as pictorials that show you how to do oil changes, transmission changes, and differantal changes, even spring changes.
Other than coming to your house and doing it for you I dont know what else Mike or any of the other people that worked in the links amd pictorials could do for you.
Old Mar 26, 2012 | 01:07 PM
  #57
wiscodread's Avatar
I used this list when I did my 60k tune-up; at that time, as I remember, Dexcool was listed as the coolant to use. Now, it says used green coolant and NOT Dexcool. Did I read the post wrong 60k ago? Have things changed?
Thanks
Old Apr 11, 2012 | 06:37 PM
  #58
jobooth's Avatar
Just about to do my first maintenance on an '04 I just bought
U joints, rotoflex, front drive shaft centering kit, oil, filter. PO did just about everything else last year. I'm seeing some seepage around the transfer case. I'm gonna check out bolts and tighten everything up.
Woohoo!
Old Apr 14, 2012 | 04:39 AM
  #59
Mike04's Avatar
hello there,
I'm about to buy 03 Disco SE . it has 200,000 miles on it , but looks great almost like brand new , Any Ideas ??
Old Jul 6, 2012 | 11:57 PM
  #60
chorizote's Avatar
5th Gear
Hey, am doing some work on my D2, also doing an oil change, I was looking for the K&N filter but it says to use a different filter, not the 3001, it tells me to use the 2004, am i doing this wrong? or the Major Service thing was genetic, or specific to D2s?
Julian
