Major Service.
Old Oct 8, 2010 | 07:51 PM
  #31
ringerso's Avatar
Thanks for posting this DiscoMike...very, very helpful!
Old Oct 23, 2010 | 11:47 PM
  #32
Zagorfly's Avatar
I have an easier solution:
Bring your Discovery to the Biggs Brothers in Bellevue. Steve Biggs and his crews is honest and professional giving you back a complete new car to enjoy. I have done my major ($4K) service to our Disco there. I love them ! they deserve business.
Old Dec 6, 2010 | 10:18 AM
  #33
newworld's Avatar
Default listen to discomike
discomike knows his stuff.....listen to him newbies....he has helped me out alot......
Old Dec 7, 2010 | 02:32 AM
  #34
2001SE7's Avatar
Default me too
Ditto.
Old Dec 7, 2010 | 10:16 AM
  #35
buick215's Avatar
I have never heard of a $4K service. The 60k mile service which is the biggest I think is $1k at the dealer. With a little more than $4k I can just throw in a new engine and at the dealer to top it off.
Old May 23, 2011 | 12:13 AM
  #36
tshah209's Avatar
Default fuel additive
Originally Posted by Disco Mike
For those of you buying a used vehicle with 60K or more on it, consider doing the full list to bring your truck current.
1 Oil filter, K&N 3001 or Mobil 1- 301
1 Factory air filter
6 Qts. of engine oil
2 feet of 3/16th vacuum tube
2 feet of 5/16th vacuum tube
12 Qts. of ATF
7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use
3 Pints of synthetic DOT 4 Brake fluid
2 Qts of synthetic Power steering fluid
2 Gallons of Peak or one of the other green or yellow coolants, not Dexcool
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platinum Plus 4's
1 Set of Magnacor or STI 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
1 bottle of WaterWetter or Purple Ice
Hoses and belts, as necessary
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Change the coolant and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
DiscoMike--what do you use for a fuel additive?
Old May 23, 2011 | 05:37 AM
  #37
antichrist's Avatar
Forum use tip #1
When responding to a post, particularly a lengthy one, generally there there's no need to quote the whole post.
i.e.
Old May 26, 2011 | 09:01 AM
  #38
annes99landrov's Avatar
7th Gear
hello,im looking for disco mike if possibile.i bought a 99 discovery II and the alarm will not deactivate.is there a way to bypass the alarm. im new to this site and at 1 time you posted your phone number,but i misplaced it .my number is 509-637-5885 my name is anne. thanks
Old May 28, 2011 | 07:33 PM
  #39
tshah209's Avatar
Thumbs up Done
Okay, I did everything on Disco Mike's list except for lubing the drive shaft and change the spark plugs and wires (this was done recently for me after I had the engine swapped a little over one year ago). I also replaced my 2000 disco's (with 142,000 miles) front shock struts with Bilsteins hd, rotors (the new ones are Royalty slotted/drilled), and brake pads (Hawk LTS).
As for Disco Mike's list:
  • Engine flush
    • I used the Gunk Motor Flush
      • I did it a little differently then prescribed. First, I drained the oil (did not change the oil filter). I then added 4 qts of cheap 5/30 conventional oil (for sale) and added a qt of the Gunk. I then ran the engine on idle for 5 minutes. I immediately drained the oil and changed the oil filter. I was amazed by how dirty the new oil was!!!
  • Drained both the differentials.
    • Dang the synthetic 75/145 gear oil was both expensive and was hard to find. I ended up driving out of town just to find my last three qts. Next time I will do my due diligence and shop for the gear oil ahead of time using the net. I'm disappointed by how much I spent on the gear oil.
    • The front diff was the hardest to fill because the bars in the front of the diff made it difficult to elevate the bottle high enough to flow through easily. My hands and forearms got sore from trying to squeeze the thick gear oil into the front diff pumpkins.
  • As for the transfer case. Getting the filler nut off was a major pain. There just was not enough room. I was eventually able to get it off by using a universal socket joint.
  • Transmission fluid and filter change.
    • Prior to doing this, I was really intimidated by the process. It was actually somewhat easy...Just messy. The Lucas transmission treatment was hard to pump in the filler hole because the fluid was thick.
  • The Seafoam treatment was the most fun. My service engine light stayed on for about 1 1/2 days. Driving around with all that smoke in the back was funny.
Questions:
My front diff pumpkin seemed to need half a qt more gear oil than the back one. I thought they both had the same volume?
The transmission only took three quarts of fluid and one qt of the transmission treatment. I thought it filled up with 5 qts total. After it initially topped off, I did put the filler hex nut back on and started the engine and then switched my transmission from P to 1 (two seconds per each shift) and then returned back to P (on the way back, two seconds (repeated)). Did I do something wrong?
After finishing up all the work. I spent 30 minutes cleaning up the driveway!
I did all of the work yesterday. My neck is still sore from spending all of that time underneath the disco.
I feel relieved and proud to get all of this work done.
Do any of you know how much labor costs I saved by doing all of this work???
thanks to all for your forum threads. They helped me tremendously!
Old Jun 2, 2011 | 05:36 PM
  #40
Take THAT, Jeep!'s Avatar
Hey Disco Mike,
I started your list by having my oil changed. I have only had the car for a month and so this was my first oil change. I had them put in Rotella 15w-40 (from what I've read on this forum) and a Valvoline Oil filter. Yesterday afternoon after I got home, I noticed the engine had a steady knock to it when idling. So I checked the oil and it was right on full. Is the oil too thick for my car?
