Ok i give up !!!!! Help !!!!!
going to recheck the security system and swap cam sensors , if that doesn't work I guess im going to pull the motor back out and check the flywheel again, anyone have any other ideas???????? call or text me at 8457543236 I'm going in to the garage and not coming back out till one of us wins this fight
Was the front cover already on it when you got it? Sounds like the timing is off. who put the timing chain on? I'm just wondering if the timing marks on the gears/chain sprockets are not lined up but, if they put it together I'm sure they would have got that right.
ok, so this is a little late , as the truck is fixed and goon , but here go's , so after checking and rechecking everything you have posted to help I decided to go back to the beginning , so after 5 hours the motor came out , and there it was the flywheel was installed wrong , the guide pin was pushed flat and I put it back on right and 5 more hours it was back in. And guess what. it started the first turn of the key. truck is running great and made it back to Colorado running 80 mph and got 17 mpg all the way , I even fixed most of the tire wobble the truck had I thank you all for your help , come spring time I will post up how the exhaust go's on we plan on doing long tube headers and duals .
wileyabbas
05-23-2008 02:50 PM
