Mysterious Item Found Under Valve Cover
Old Oct 21, 2014 | 09:28 PM
coors's Avatar
Default Mysterious Item Found Under Valve Cover
I finally got my heads off today. But after I removed the drivers side valve cover I noticed a tiny round copper-like spacer looking item sitting on the rocker assembly. Does anyone know what this is and where it came from?
It's roughly 5/16" in diameter maybe a little smaller. I'll try and post a pic tomorrow.
Old Oct 21, 2014 | 09:37 PM
dusty1's Avatar
Part of separator ??
Old Oct 21, 2014 | 10:00 PM
RicketyTick's Avatar
Probably one of the metal spacers from your valve cover gasket. Look at the old gaskets to see if one or more are missing.
Old Oct 22, 2014 | 06:19 AM
lordmorpheus's Avatar
X1 on the valve cover gasket spacer.
Old Oct 22, 2014 | 08:14 AM
drowssap's Avatar
Old Oct 22, 2014 | 05:52 PM
coors's Avatar
Crap. Should I have saved it? I can't find the little bugger now.
Old Oct 22, 2014 | 06:41 PM
If you can't find it, you could take another one out of the gasket and try to find or make something suitable. They are just in the holes of the gasket so the gasket cannot be overtightened. If you don't have one to put in when you're putting it back together, just remember that, and don't rely on "torque feel" when you tighten down that bolt. Might have to count turns instead or something to that effect.
Edit: Long day at work... If you are replacing head gaskets, you are going to have new valve cover gaskets too..
Disregard anything above
Old Oct 22, 2014 | 06:56 PM
Your new gaskets will have them already. just be careful when putting your new gaskets on and don't let any come out and get away from you. You may want to hang on to your old gaskets/spacers just so if you did loose one from a new gasket you could steal one from an old gasket.
Old Oct 23, 2014 | 05:21 AM
drowssap's Avatar
don't worry about it, i don't even use them just don't torque the crap out of the valve covers.
wallyman424
Dec 13, 2012 11:14 AM
txjag1023
Aug 29, 2012 08:22 AM
jafir
Jan 24, 2012 12:45 PM
LRD2&ME
Aug 1, 2011 07:02 PM
RoveringAgain
Nov 20, 2009 02:28 PM
