P0171 p0174 p01173
I have the 1173 code. I've had it for along time. It went away for a bit and all the research I did lead me to air leaks in the exhaust. I have tiny hole in my pre-cat exhaust and the code still pops up once in a while. It has no effect on milage or drivability just that damn CEL. I just delete it with my scan gauge whenever it pops up. no more vehicle inspections in my neck of the woods anymore starting jan1/2015...yeeehaaa!
For the vac problem I should note that I have no brake assist for at least a minute after I start my truck, and I have a steep driveway! Then, approximately ten seconds later, I have good assist but when I use the brakes and released then use them again (car coming that I didn't see), there is no assist in the second press. I guess that can be a vac leak anywhere
This weekend I am putting on my new crank seal, water pump, front cover, and oil pan gasket, to solve numerous leaks. Basically, I see every fluid except transmission, brake, and diffs. All of this is weather and wife permitting. I will have the fan off so it will be a good time to put smoke everywhere.
Can anyone snap a picture or be real specific about where I should looks for vacuum leaks? I don't know anything about brakes beyond replacing the pads and bleeding the system.
Beside the point my 29 dollar eBay power steering pump is not happy, either, but the leak is slow at the moment. I need but won't get castor correction (for lift) and have wider tires, so replacing power steering pumps may just be part of the deal. Thanks for letting me vent
