P0202 after intake manifold gasket replaced
Old 07-23-2012, 01:50 PM
rick.miles's Avatar
Default P0202 after intake manifold gasket replaced
Just picked up the truck from the mechanic. It's been there almost 2 weeks. Drove it out of his garage and the CEL started to flash. Took it back to him and code P0202 shows up on the scanner. Misfire on cylindar #2. Could this be because he was replacing the manifold gasket and got coolant on it?!?
He recommened I run some "heat" through the fuel tank to see if that clears up the injectors etc.
What are your thoughts? I had the wires and plugs replaced about 2 years ago and my wife only drives around 3000 miles per year in it.
Old 07-23-2012, 03:50 PM
Actually a P0202 would be injector wire for #2 injector loose or off. 302 would be misfire.....
Frome RAVE:
P0202 Injection circuit malfunction - cylinder 2 Injector 2 open circuit
Old 07-23-2012, 04:07 PM
rick.miles's Avatar
What do you recommend I do?
Old 07-23-2012, 04:14 PM
Return to mechanic with that info, it may be just a wire is loose on that injector, or it may be the wire harness was pinched by manifold work. Here's the page from the Rover shop manual to print out and take with you.
Now to be fair, some code scanners come up with the right numbers but put in text that does not match the Rover manual. That is why we always ask people to right down the numbers. Probably a 30 second fix.
Also, hope he doesn't look like my mechanic....
Attached Thumbnails P0202 after intake manifold gasket replaced-bad-mechanic.jpg
File Type: pdf
Old 07-23-2012, 06:05 PM
rick.miles's Avatar
Thanks for your help. I hope he doesnt try and screw me on this.
Old 07-24-2012, 08:59 AM
Your mechanic is an fool if he didn't realize he knocked the injector wire loose. If he fights you on this and you paid by credit car then stop payment on his money till he fixes the problem.
Old 07-24-2012, 03:24 PM
rick.miles's Avatar
Mike;
I droppped it off there this morning with the info Savannah Buzz gave me. Also printed him a copy of the Rave manul for future use. At this point in time, he seems a little embarrassed by it. Hoping he'll call me later to collect it.
I'll keep you posted.
Old 07-24-2012, 03:29 PM
The RAVE on a USB drive is handy to keep in the glove box....
Old 07-24-2012, 03:42 PM
rick.miles's Avatar
Yeah, printing that thing at Staples wasnt fun. But I thought worth the effort.
Old 07-24-2012, 04:23 PM
Sir, you just moved to the hard core department..... my hat is off to you.
Quick Reply: P0202 after intake manifold gasket replaced
