Pictures of coolant drains on Disco 2?
Old 06-21-2009, 01:55 PM
lipadj46's Avatar
Default Pictures of coolant drains on Disco 2?
I'm trying to figure out where the coolant plugs are on my disco 2. I know there is one on each side but I cannot decipher where they are even with the Rave CD drawings. Anyone have pics?
Old 06-21-2009, 02:51 PM
lipadj46's Avatar
I found the drivers side plug but no luck on the passenger.
Old 06-21-2009, 03:01 PM
Dont worry about them, just remove the lower radiator hose.
Old 06-21-2009, 03:12 PM
Can you post some pics?
EDIT:Sorry, this went into the wrong thread.
Old 06-21-2009, 05:44 PM
lipadj46's Avatar
Pics of what, the plug? I did end up also removing the lower radiator hose but I was following the manual procedure and could not find the passenger side plug, not sure it exists.
Old 06-21-2009, 05:55 PM
Jupiter Rover's Avatar
I need to change my coolant. Let me go run out and look. I have a good size lift and get under it easy. brb.
Old 06-21-2009, 06:17 PM
Okay, the driver side one is next to / behind the exhaust header.
The passenger side one is Right behind the Engine Mount Plate. The plate connect to the engine and the mount, there is a space for your hand to go through and you can feel it.
1thunder
02-07-2010 02:28 PM
Night Train
12-02-2008 06:17 PM
theRange
09-07-2007 03:55 PM
arrkerr
12-14-2005 10:06 AM
Quick Reply: Pictures of coolant drains on Disco 2?
