Need help!!!! Centering ball removal
Old Jun 20, 2009 | 12:45 PM
clemson rover's Avatar
Default Need help!!!! Centering ball removal
I am in the process of replacing the u joints and centering ball on my 03 Disco. I have all of the u joints out but ran into trouble with the centering ball. I rented the slide hammer from advance and followed the instructions on the "front prop rebuild" pdf. When removing the ball the race did not come out with the ball. Any suggestions??????
Old Jun 20, 2009 | 01:26 PM
PalmettoDisco's Avatar
Split the race with a sharp chisel and hammer. Look at the replacement and you'll see a small lip at the top. On the old one, split this lip then work down the side about halfway. At this point you should be able the bend the race a little and slip a screwdriver behind the race and pry it out.
Second option, use a dremel tool to cut the race.
Third option, use a torch to heat the race and bend\pry it out.
Go *****! *(I like my "taters" mashed!)
Old Jun 21, 2009 | 08:15 PM
I ended up using the dremel. It took a while just trying to be careful.
whiski runner
Aug 6, 2012 05:43 PM
CampCobb
Aug 6, 2009 01:23 PM
jw928
Feb 28, 2009 10:26 PM
holly5
Jan 24, 2009 12:28 PM
Night Train
Nov 28, 2008 11:17 AM
