replace PS pump or install new seal???
Old Mar 25, 2011 | 01:21 PM
carpe06303's Avatar
4th Gear
Default replace PS pump or install new seal???
2002 Disco II
My power steering fluid has drained completely from my car. Landrover quoted me $1,055.37 for parts and labor to replace the 3 hoses. I decided to try to fix it myself and purchased the hoses from roverparts.com for $169. I replaced the hoses and wala, the hoses weren't the fix, its the pump. Seems like once there is pressure in the system the fluid is leaking out of the gasket on the pump. I found a Power Steering Pump Seal for sale here (Best Parts Online Product List). My question is, is has anyone replaced the gasket and it fixed the issue? I have searched quite a bit and only found people that replace the entire pump. I would rather pay $20 for this seal kit than $300 for a pump.
Old Mar 25, 2011 | 02:10 PM
swgrinnell's Avatar
5th Gear
carpe06303,
Does the pump also make considerable noise when the wheel is turned, i.e. is air being sucked into the pump? I have a similar problem and would like to know how the seal replacement turns out if you decide to do it.
Old Mar 25, 2011 | 02:22 PM
Bundu's Avatar
Banned
Others have posted that they resealed the pump with RTV.
At $20 give the seal kit a shot and let us know.
Old Mar 28, 2011 | 06:46 AM
carpe06303's Avatar
4th Gear
It only started making noises after the PS fluid drained out. Other than that, no noised.
Old Mar 28, 2011 | 07:44 AM
drowssap's Avatar
I vote go got the $20.00 o-ring & put a thin coat of RTV on it.
Old Apr 18, 2011 | 06:21 AM
swgrinnell's Avatar
5th Gear
After finding your post, I decided to also give the seal kit a try. I actually only used the pump casing gasket (didn't bother with the shaft seals), and the symptoms have completely stopped. It drives like a dream now. So, yes. For $20, I would recommend it.
Old Apr 18, 2011 | 09:23 AM
DiscoRover007's Avatar
My seal was busted and I used universal gasket material and RTV and it has worked like a charm. Just do it right and tighten like hell. I also replaced the return hose with tubing and springs from autozone. Beats paying 100 bucks in hoses and whatever it is for a new gasket.
Old Apr 18, 2011 | 09:37 AM
sloan74's Avatar
I would try this first.
x2
Old May 6, 2011 | 03:47 PM
newworld's Avatar
Default power steering pump/hoses t 160k miles
i had a leak....ok...not a leak, a gusher out of the power steering pump area. it "looks" like the suction hose, but in reality it is the pump. for anyone having this problem, let me tell you my experience....i first removed the pump, and resealed it with rtv.....and did not change the suction hose, used the old one.....after about 5 minutes no whining sound, everythings seemed good...then test drive......leaking started again, not as severe as first time but the same.....removed everything again, bought a reman pump, and a new suction hose, and reinstalled everything, no leaks, all good. one note::: bleeding the power steering box is a pain......there is a trick one other member posted somewhere, and i congrat him on it, take a long piece of vacuum tubing and place it on the nipple, and the other end submerged in your full p/s reservoir.....run the engine, then lock to lock, do not need to jack up the car....it works like a charm...then tightened the nipple.
Old May 6, 2011 | 03:50 PM
newworld's Avatar
also for newbies to this project, the gasket is most definitely bad, but inside the pump, there are valves and it also be stuck of malfunctioning....so if you are short on time for repair, get a replacement pump it saves a lot of agravation....but if you have the time to tinkle with it and can install and remove the pump multiple times.....then by all means tinker away....but i warn those that sometimes the whining sound is due to a "bad" pump as well as a bad gasket.....so if your rig has a lot of miles it is better to change the pump and not worry about it......
