replace PS pump or install new seal???
Old Oct 1, 2011 | 05:04 AM
  #21
sebastian's Avatar
4wd High
Default Steering pump leak. tutorial how to fix it.
Hello, here is a step by step tutorial how to fix the power steering pump leak on 620Ti
suitable also for:
Land rover Discovery
Land rover Freelander
Land rover LR3
Land rover Range Rover
Rover 220 Petrol (Turbo Non-Turbo) (1994 to 1999)
Rover 220 Diesel (Turbo Non-Turbo) (1996 to 1999)
Rover 420 Petrol (Turbo Non-Turbo) (1994 to 1999)
Rover 420 Diesel (Turbo Non-Turbo) (1996 to 1999)
Rover 620 Petrol (Turbo Only) (1992 to 1999)
Rover 620 Diesel (Turbo Non-Turbo) (1996 to 1999)
Rover 820 Petrol (Turbo Non-Turbo) (1994 to 1999)
MG ZR Diesel (1999 to current)
MG ZS Diesel (1999 to current)
Old Oct 1, 2011 | 05:05 AM
  #22
sebastian's Avatar
4wd High
Default Steering pump leak. tutorial how to fix it. part 2
Old May 9, 2012 | 06:17 PM
  #23
John Smith's Avatar
5th Gear
The link didn't work...here's the link to that kit...
Power Steering Pump Seal Kit for LAND ROVER Discovery II 1999 2000 2001 2002 2003 2004
Originally Posted by carpe06303
2002 Disco II
My power steering fluid has drained completely from my car. Landrover quoted me $1,055.37 for parts and labor to replace the 3 hoses. I decided to try to fix it myself and purchased the hoses from roverparts.com for $169. I replaced the hoses and wala, the hoses weren't the fix, its the pump. Seems like once there is pressure in the system the fluid is leaking out of the gasket on the pump. I found a Power Steering Pump Seal for sale here (Best Parts Online Product List). My question is, is has anyone replaced the gasket and it fixed the issue? I have searched quite a bit and only found people that replace the entire pump. I would rather pay $20 for this seal kit than $300 for a pump.
Old May 10, 2012 | 06:02 AM
  #24
sebastian's Avatar
4wd High
Default Land rover power steering pump gasket
try this
Rover Power Steering Pump Gasket + step by step tutorial / Land Rover fits too | eBay
Old Aug 18, 2012 | 02:35 PM
  #25
John Smith's Avatar
5th Gear
The main gasket has sealant on one side. Does that go towards the aluminum cover or the steel pump?
Old Aug 18, 2012 | 02:38 PM
  #26
John Smith's Avatar
5th Gear
Default how to install the main gasket?
Thanks for your help!
Originally Posted by swgrinnell
After finding your post, I decided to also give the seal kit a try. I actually only used the pump casing gasket (didn't bother with the shaft seals), and the symptoms have completely stopped. It drives like a dream now. So, yes. For $20, I would recommend it.
Old Aug 18, 2012 | 03:56 PM
  #27
BrandonS's Avatar
Mine was leaking pretty bad. Emptied the entire contents of the resevoir out overnight. I ordered the kit online and just replaced the gasket in the middle between the two halves. Doesn't leak anymore.
Old Aug 18, 2012 | 06:55 PM
  #28
jfall's Avatar
I replaced my PS pump with al Allmakes from British Pacific at about $330 for the part.
We have an Allmakes PS OEM pump in:
1997 Discovery
2001 Discovery II.
Running fine.
But, the most satisfaction will be in rebuilding your pump, I am sure.
Old Oct 16, 2012 | 05:16 PM
  #29
John Smith's Avatar
5th Gear
Here's the rebuild video using kotek's sk-9170 or 28-1930 kit.
www.facebook.com/video/video.php?v=429928983732557&ref=notif&notif_t=vide o_processed
Old Oct 17, 2012 | 12:57 AM
  #30
jfall's Avatar
New PS pump about $230.
British Pacific.
Aftermarket.
Took about an hour to install.
Don't over tighten the 3 10mm bolts on the pulley - it will break the pump metal.
Bleed it with the bleed screw on the steeering box.
and you are good to go.
Fairly easy job.
Just slow with the hoses.
