Seafoamed the neighborhood and got an SES
Finally got around giving the old girl the seafoam treatment and as advertised, I laid a few hundred yards of white smoke through the neighborhood. I couldn't tell if the people I passed were cranky about it, because they disappeared behind a wall of smoke...
Anyhow, I now have a "service engine soon" light on and I'm not sure what to do about it. I have an Ultragauge on the way and am wondering if I can turn the light off with that.
Anybody know?
Anybody know?
Usually after a good fogging the spark plugs need to be changed, nothing like tossing liquid carbon on em to see if you can cover the electrodes 100%...... It's always recommended to require new plugs before you fog your cylinders. Might want to take a few of em out to take a looksee.
You gave me a good laugh with the "Seafoamed the neighborhood...." I can picture the white cloud......LOL!!!!
Did you know you can do the same exact thing with water? Just do it slower. When I want to blow carbon out I just step on the skinny pedal while rolling, gray cloud instead of white.
[QUOTE=ihscouts;501190]Usually after a good fogging the spark plugs need to be changed, nothing like tossing liquid carbon on em to see if you can cover the electrodes 100%...... It's always recommended to require new plugs before you fog your cylinders. Might want to take a few of em out to take a looksee.
Thanks for the response but I'm not sure what you mean by "recommended to require new plugs before you fog your cylinders" if you're recommending that they be changed afterwards.
Did I miss something?
Typically you "fog" a motor on worn plugs. Once done you replace your worn plugs with new. You time the Seafoaming to when it's time to replace old plugs. In other words, don't Seafoam the engine using new plugs because you will more than likely foul them and have to replace them anyways......
Seafoam might bugger up your O2 sensors.
Be careful.
You can read about my fun with O2 sensors below:
http://jeffreyfall.com/landrover
Be careful.
BlackDiscoII
06-02-2012 08:58 PM
