Shuddering
Old 08-24-2011, 11:11 PM
cornerz's Avatar
Question Shuddering
Hi
i have experinced a intermittent shuddering.
This usually happens not long from starting the vehicle. It seems to disappear once the vehicle is warm.
I had recently had the engine oil and transmission oil changed with the filter. It didn't do this prior to the service.
Does anyone had this experience? not a mechanic just a guy who changes the oil and the odd filter now and then.
Old 08-24-2011, 11:22 PM
disc oh no's Avatar
My '03 had a sort of hesitation once in a while but I think the cause of mine was a cam bearing that had fallen out of the block and then was getting wedged between the cam and lifter occasionally sticking that valve open and causing it to hesitate. I think that may also have been the cause of the tick in my engine but I'm not sure. I'll have to get the new head gaskets in and give it a test drive.
Old 08-24-2011, 11:23 PM
disc oh no's Avatar
Oh yeah, also mine has this hesitation but no Change engine light. probably because it's not electrical or whatever.
Old 08-24-2011, 11:29 PM
lordmorpheus's Avatar
Check engine light on?
Might want to have codes scanned (in case it hasn't triggered due to drive cycles, etc) even if the light it not on.
Old 08-25-2011, 04:26 AM
Does it shudder in park with engine reved up slightly, or is it related to the tranny and moving? Maybe wrong type of fluid was used, or the old fluid remaining in the torque converter has diluted the new fluid (with respect to cleanliness). Was tranny filter changed or just engine oil filter?
Old 08-27-2011, 12:04 AM
cornerz's Avatar
The shuddering happens usually in drive and sometimes in reverse. At stationary or slow speeds <30kms.
funnily enough when it is slightly revved it disappears.. go figure?
dex 3 was used for the tran and i also had a new filter kit put in the transmission.
good point about the torque converter i will ask the mechanic if he cleaned the old oil out of the torque converter
One time the sports mode and manual mode came up flashing this was fixed by turning the engine off and on again. (this happened only once)
Old 08-27-2011, 08:42 AM
You may want to verify how much fluid he installed and if you know how, check the fluid level, you may be low.
jdog30014467
02-09-2014 02:31 PM
grantj727
02-12-2011 02:12 PM
clemson rover
05-21-2010 11:31 AM
TheRedRockDisco
05-05-2010 06:27 PM
bangkuaidiscovery04
07-17-2009 08:50 AM
Quick Reply: Shuddering
