surging at idle
Old Oct 20, 2009 | 04:55 PM
tweakrover's Avatar
Default surging at idle
now that i got my overheating problem sorted out on to the next. at idle the truck doesn't stay at a constant rpm, now i have a stepper motor code but changed it but it won't go away. in drive at idle it idles pretty nice most the time maybe dropping once in a while. any imput would be great.
Old Oct 20, 2009 | 05:52 PM
Lets start from scratch, what have you done to try and correct this problem so far?
Old Oct 20, 2009 | 10:57 PM
tweakrover's Avatar
well, new plugs, wires cap rotor, stepper(from advance the one that cross referenced the ac delco number) i checked the trottle potentiometer with an ohm test , head gaskets and up, vac hoses seem fine. the only thing i can think of is if the o2s are sending a bad signal making the stepper act weird causing the light and the surging.is that possible?
Old Oct 21, 2009 | 10:28 AM
As Spike will tell you, you will need to go have your new IAC set up to your ECU so the idle will be where it belongs.
Old Oct 21, 2009 | 03:45 PM
tweakrover's Avatar
i thought that wasn't the issue with d1s, if it is what is the procedure, or what tools do i need, I'm going to a lr rally this weekend with a big group of rover guys together someone may have what i need.
Old Oct 21, 2009 | 04:28 PM
You wil need a scanner with the proper software to reset your IAC, you'll need to call around and find a mechanic who can do it for you.
Old Oct 21, 2009 | 05:16 PM
The IAC on a DII is not old enough to fail yet, but on a DI they are and you need to have your ECU reset by the dealer.
It is a 50/50 shot if the new one will need to be reset or not, yours needs to be reset.
Old Oct 21, 2009 | 08:48 PM
tweakrover's Avatar
if its a 50/50 chance than i'm not buying any lotto tickets anytime soon cause my luck is nonexistent. what type of system do they need so i don't sound like a moron asking if they have the computer thingy to reset the iacv?
Old Oct 21, 2009 | 09:21 PM
T4 or TestBook.
XCELLER8
Nov 18, 2019 07:14 PM
tweakrover
Nov 16, 2010 09:43 PM
krazzz
Jul 13, 2010 03:13 PM
stangchic50
Jan 22, 2005 08:20 AM
lowridersvt
Nov 10, 2004 07:36 AM
