Thermocouple placement for engine temp.
Old Mar 29, 2012 | 08:43 AM
EVN137's Avatar
Default Thermocouple placement for engine temp.
Has anybody ever tried popping out a block plug from the engine and modifying it to accept a thermocouple?
This idea came to mind a while back when I bought an engine block warmer for my Disco and it required you to put it in one of the block plugs.
Any thoughts/suggestions/comments are welcomed.
ps: it's still in the box ( block warmer ).
Old Mar 29, 2012 | 10:47 AM
Perhaps consider removal of supply hose to throttle body, that provides a spot adjacent to the ECT at the top of the manifold. Then T tap throttle body supply line to heater supply line with in-line reducer. On the D1 manifold, there is a separate gauge sensor, and below it on the front of the manifold is an un-used plug, on prioor models it was heater supply line. Peoplae have drilled and tapped that plug.
TX D2
Apr 3, 2012 10:23 PM
Disco_Fever
Feb 17, 2011 01:49 PM
NWDiscoRover2004
Feb 25, 2010 05:53 PM
Chrisinhouston
Oct 16, 2009 09:07 PM
FINISHMAN
Jan 8, 2008 02:15 PM
