Transfer case seals
Transfer case seals
My Transfer case is really leaking. At this time I would be working outside, in a parking lot, so do not want to remove the transfer case. Eventually, I want to swap in a locking case, but for now would be happy to just slow the leaking.
What is the difficulty level of these seals? Are they accessible without lifting the truck? I took a look at Rave, but would love some anecdotal feedback.
Also buy an oil seal removal tool as they are easier to use than a screwdriver.
Avertissement de redirection
CollieRover (04-29-2016)
Unless you are extremely slim you'll defo need to raise the truck onto axle stands. The difficulty factor is say around 2-3 out of 5 as the rear seal has to be accessed by taking off the driveshaft, handbrake assy and flange and the front by removing the driveshaft and front flange. You'll need new nyloc nuts x2 and new felts washers x2 and also front and rear oil seals. The two nuts are on tight so you'll need to have a gizmo to hold the flanges and a long (say 30") 1/2" drive breaker bar to undo the nuts and a torque wrench to finally check them when replacing the nuts. My time estimate outside using axle stands and the right tools would be 2-3 hours maybe as much as 4 hours first time around. Good luck and have fun.
So far the new seals are not leaking, and the Rightstuff Gasket is not leaking at the inspection plate.
A Offroad mentioned the Oil Seal Removal tool is a must, and I was able to use my Harbor Freight Impact Wrench to get the nuts off of the output flanges.
To get the seals seated I used a PVC pipe and a rubber mallet. So prior to doing this job take your seal to a hardware store, and get a size of PVC that will fit.
It was not a fun job twisting underneath the car, and just make sure you have good tools to remove the driveshaft.
CollieRover (08-14-2016)
Thanks Off-road! Next big project is to fix oil leaks underneath the lower intake manifold. I will do wires, plugs and rebuild the fuel injectors too.
