Uneven Rear Brake Pad Wear
Old Mar 30, 2012 | 12:34 PM
Disco Alan's Avatar
Default Uneven Rear Brake Pad Wear
Recently I noticed that there is some squeaking from the right rear when I brake. I thought it's just that the brake pads are wearing down. Upon a closer look I noticed that my right rear pads are wearing significantly faster than my left rear. The truck doesn't pull to one side or another when I brake though. What sort of problem should I be expecting? I want to get the right parts on hand before pulling the rear brakes. Thanks.
Old Mar 30, 2012 | 12:54 PM
NoBama316's Avatar
Caliper could be sticking slightly causing it to "drag" on the rotor a bit.
Old Mar 30, 2012 | 03:35 PM
Disco Alan's Avatar
Thanks for your response. If that's the case, is this the fix?
Caliper Service Kit - Rear
Caliper Service Kit - Rear (Part # STC1909) - Land Rover kits from Atlantic British
Old Mar 30, 2012 | 07:59 PM
Perhaps, but sometimes the caliper piston has also scored the cylinder wall, etc., and you end up replacing the whole thing. I found my sticking caliper with an IR thermometer. One disk was 40F hotter than other disk on same axle.
Old Mar 31, 2012 | 03:54 PM
Disco Alan's Avatar
In that case did you end up replacing the whole caliper+piston set?
Or could I get away with a new piston and the caliper service kit?
Old Apr 1, 2012 | 07:29 AM
If it can be honed out and rebuilt then do that, if not buy a rebuilt caliper.
Make sure to replace both rear brake pads and do a full 2 quart DOT 4 brake flush when you are done.
RITTER
Aug 24, 2012 03:16 PM
morganfromaustin(in PDX)
May 4, 2011 04:28 PM
tsuami1
Mar 1, 2009 09:32 AM
01 Discovery
Dec 1, 2006 12:07 AM
Prepilot_3ck
Apr 1, 2006 10:35 AM
