what is code p1590 ?
I had a autologic read my faults today. It read P1590 And the tech said it was abs ecu failure. He also sadi the ecu may have damaged some wiring. I am wondering what i should do next. I was going to spend the money on an ABS modulator Kit for 800.00 from rover parts but i do not want to purchase the wrong part. I have already tried the cheap fix ( shuttle valve kit) and that did not work .The tech says i need an ECU ..Is the ECU on the computer side of the MOdulator. Would appreciate any helpCaleb
RE: what is code p1590 ?
http://www.troublecodes.net/landrvr/
Gives all the codes for the Land Rover OBDII system. I found it pretty helpful
The following 3 users liked this post by AK Rover:
I had to re-register today whats up with that?
Thanks man,
Jeff
Disco mike, hi I'm norm and I had this code come up along with three lights. The abs, traction control, and decent light. They came on after I wash it and started it to go somewhere. Any idea why this is?
