Forum Help & Suggestion Center This section is NOT for vehicle technical questions. This section is for problems or suggestions for the forum itself.
2004 Discovery vibration
Old 01-09-2017, 11:12 AM
MXG's Avatar
MXG
MXG is offline
Default 2004 Discovery vibration
First time to post a thread.
Hello all,
Have symptom of “drive through” vibration.
Land Rover Discovery 2004, purchased at 47K, now with 100K miles.
Purchased from Land Rover dealer, no off-road use.
Vibration at about 40 mph and again at about 60-65 mph.
Vibration is sensed in the coach or body with very little
at the steering wheel at 40, only in the body at 60-65.
Tire changes, Hunter align and balance, steering damper, drag link, front drive shaft (saved the original!), flex coupling. Rear u-joint okay. Grease front drive shaft and replace nipple with plug. Mounts appear okay. Vibration has not become worse.
All major work by Land Rover.
Some of my research indicates that the yokes of the front diff and xfer
case should be out of phase with each other by 180 degrees. This appears to be compensated by the design of the 2004 front drive shaft. Does anyone
know if that applies the 2004 Discovery?
Any comments will be appreciated.
MXG
Old 01-10-2017, 08:47 AM
LR03NJ's Avatar
Hello all,
MXG
Seems like you have checked everything. Im not sure, but I think it will be better if you post this on Discovery section. If I have major problems, I get comments immediately. Just try it there.
Old 01-19-2017, 02:15 PM
Best4x4's Avatar
Received 2,239 Likes on 1,662 Posts
Make sure the panhard rod bolts are tight.
Old 01-20-2017, 08:43 PM
MXG's Avatar
MXG
MXG is offline
Default Panhard rod bolts
Thanks for the tip. Will check.
MXG
Duke
11-15-2012 09:09 PM
hman
07-08-2012 08:11 AM
97discofl
12-02-2010 09:25 PM
Sport4Auto
02-27-2007 06:52 PM
shagybruce
01-27-2007 06:48 AM
Quick Reply: 2004 Discovery vibration
