Freelander Talk about the Land Rover Freelander within.
code problem for a 2003 freelander
Old Jun 5, 2010 | 01:10 PM
fast5point0's Avatar
4th Gear
Default code problem for a 2003 freelander
i have a 2003 land rover freelander se i have trouble codes and they are p0455 and p1471 and p1472 can anyone help me with them cause i found a site with trouble codes for the land rover and none of these codes come up. auto zone say's that p1471 and 1472 come up as failed leak detection pump and p0455 came up as large leak in th EVAP system and say's probable cause is 1 defetive or loose or missing fuel cap 2 EVAP canister broke or hose cracked or not connected 3 purge or vent solenoid defective 4 vacum leak at engine can anyone help me with these codes and help figure out what is wrong with it. i tried to look for the parts online but have not come up with any so far
Old Jun 5, 2010 | 01:40 PM
Rovin4life's Avatar
reinstall the gas cap and clear the codes. 1472,1471 are useless codes. Intake motors do not go on these.
1472,1471 are VIS motors. Trust me despite what the internet says those codes come back due to some oil in the motor but it doesn't kill the vehicle. Oh and the parts dept will be happy to sell you the motors.
Clear the codes and reset the light and take it to the dealer to get diagnosed to read all the codes listed in the ecu.
Trust me if you don't know Freelanders you will misdiagnose in a heartbeat. Freelanders are by themselves when it comes to diagnosis. I get more Freelander diagnosis from shops that fail cause they throw in the VIS motors and it don't do squat.
Old Jun 5, 2010 | 01:55 PM
4th Gear
i'm a hot rod guy i can build a motor and car and set it up to go fast down the drag strip but this land rover has me scratching my head. so what are the vis motors and what do they do? i have already tried the gas cap and had the battery unkooked for about a minute and it didn't work. so i will try it again and see if it works, is there another way to rest the codes that i'm not awhere of please let me know and thank you for your help
sayeedA
Nov 15, 2011 11:02 PM
team_lunatics
Freelander
Sep 24, 2010 12:08 PM
hateroffreelander
Freelander
Sep 11, 2009 07:04 AM
gtpod
Freelander
Jan 23, 2008 12:10 PM
sph1nxx
Audio/Visual Electronics
Dec 26, 2007 11:54 AM
