If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Strange thing, removed the main Batt in the car today just to clean up the terminals and after fitting it back in, the fob is now working! Strange but its working.
Looks like CBTA works again. Funny how powering down these creatures can sometimes fix the weirdest things.
BTW: CBTA is from my tech support years. Cold Boot Try Again
__________________
2000 Disco II 113,000 miles
Maintenance: 60K service with BG fluids, front drive shaft rebuild, Denso iridium plugs, front O2 sensors, Akebono ceramics front and rear with new rotors, belt tensioner and idlers, brake fluid and coolant flushed every two years- regardless of miles
Upgrades: OEM brushguard and driving lights, 04 CDL, extended rear axle breather, DI wiper arms, heated seat kit, grey painted chalkboard headliner
