front central door locking
Old Sep 25, 2006 | 04:33 PM
william's Avatar
4th Gear
Default front central door locking
can anyone help my front central door locking has gone off only the rear will work when you press the key or the door pins down even when key is turned only the rear locks .the car is a range rover 4.6 hse
Old Sep 25, 2006 | 05:22 PM
geoman's Avatar
Default RE: front central door locking
There are electro-mechanical actuators that move the linkage in each door. There are also what is referred to as "outstations", a electrical black box behind the door panels. Sit in the vehicle and push one of the buttons down on the driver or passenger door. Do they stay down or pop back up?
The actuators do fail with some regularity, the outstations less often.
Check it out and get beack with more info. If none of the doors were locking when you turn the key in the drivers door from outside of the vehicle, the drivers door latch itself would be suspect.
Regards,
Geoman
www.eurotekapg.com
gsgtsg
Jan 23, 2008 02:16 PM
johanba
Apr 3, 2007 11:37 AM
fasterdammit
Mar 30, 2007 10:50 PM
gazthevan
Apr 14, 2006 01:28 PM
