Freelander Talk about the Land Rover Freelander within.
Bleed valve- 2003 Freelander
Old Nov 2, 2010 | 09:49 PM
leodollar's Avatar
Default Bleed valve- 2003 Freelander
Good night Rover experts,
I am running into a problem. I own a 2003 Freelander. About 2 months ago, I flushed the radiator, and added coolant. In the process, I forgot to put the cap, and drove about 400- 700 miles without it. Now, 2 months later, the AC/ HEATER air is not coming out. I believe it is a result of air in the system. I have read online on how to take air out. Some recommended to bleed the air through the valve. I cant find it. Can someone shed some light on where it would be? Moreover, can someone provide guidance on whether bleeding might solve my problem (AC/HEATER). If you have some pics or the manual diagram to share with I would appreciate.
Thank you
Old Nov 3, 2010 | 06:29 AM
Rovin4life's Avatar
its at the back of the engine look for two hoses going into the firewall. open it up and pour coolant until the coolant comes out and stops bubbling out.
lordmorpheus
Jun 11, 2011 07:00 AM
grandkodiak
May 9, 2011 08:59 PM
JavaDiscoII
May 29, 2010 04:33 PM
R0V3R
Oct 26, 2009 02:51 PM
joatman
Jan 27, 2009 12:13 PM
